Channel move is messing up my guide
I have one channel that ALWAYS says “Programming Not Available”. This is a new channel number (the tv station changed their digital signature it was 5.1 now it’s 15.1). 5.1 was CBS but is something else now (ROAR). Problem is I have scheduled recording on CBS which moved to 15.1.
I have tried rescanning, updating, rebooting, and unplugging
Hi @Ppalmeri ,
If you haven’t already, try removing the channel and saving. Then rescan, re-add the channel, and save again. That may help.
Thanks for the tip; however, I tried that and it didn’t work.
You will probably have to wait for 15.1 to update Gracenote with new guide info. You could try asking Tablo to use data from some other CBS station.
https://support.tablotv.com/hc/en-us/articles/115002199143-Correcting-Missing-TV-Guide-Data-on-Tablo#h_01JZ8XXPGX9T2CS58ESP98MQ79
Did you try a nearby zip code? That sometimes help.
Thank you, yes I did. No change. I received an email from Tablo saying they will investigate
Thanks, I’ll look through it.
I did receive an email from Tablo saying they will investigate
