Channel Missing Guide Data
In southern Ontario Canada I receive a channel called City TV on 57-1 and it is duplicated on 57-2 but 57-2 has no guide info while 57-1 did. Now 57-1 has disappeared.
So I need the guide info to show for 57-2.
Agreed, I’m having the same problem.
I tested with an antenna directly connected to my TV and verified that 57-1 is no longer available. Some kind of transmitter problem?
@Alex1234 , @AceConrad ,
Sorry you’re running into that.
Would you update your Guide Later today, and if that doesn’t work, try again tomorrow?
If you do, please let us know if the problem persists.
I’ve tried updating the Guide a couple of times but still no Guide data. I head that the station had some kind of encoder problem that was messing up their PSIP. Then I also heard that it was fixed so ran a new channel scan tonight and 57-1 was back along with the guide data.
I’m happy as well 57-1 came back and 57-2 disappeared
