Channel guide not showing up on live tab
My Tablo 4th gen tuner was working well this morning and in the afternoon stopped displaying the channel guide. I’m running on Roku Smart TV here are the specifics.
Application Version 1.1.0-734366
Roku hardware C107X
Version 14.6.4
Tablo Firmware 2.2.54
Running through Ethernet Broadband
If anybody is having the same problem you can reply on my post and if anybody can give suggestions I’m open. But before you do keep in mind I did most of the standard troubleshooting.
I just sat down to watch the evening news. Mine is doing the exact same thing. I tried rebooting my Roku, but that did not make a difference. Interestingly, I record the evening news and I was able to watch it just fine from the recording, while it was still broadcasting.
If it continues I will try rebooting the router and the Tablo puck.
@KGBnut thanks for the quick reply I will take your suggestion on resetting the router and see what it does I will keep you posted.
Ok I did the resetting of the router and the Tablo unit and still no channel menu. I guess it’s on Tablo’s end or something. It runs fine on my android phone but not my Roku TV.
I was watching some OTT so I thought I would give it a try on Roku. On Roku no Live TV grid at all. Just the spinning wheel of death for the guide data - Shows, Movies, Sports. On Fire TV stick Live Live results in “Unable to Load Live TV”. And the guide data results in “Unknown Error”.
I would guess the tablo servers are down and they still haven’t figured out how to decouple tablo from the servers.
Interesting, mine is not working on my Android phone either, at least not for live TV.
iOS app taking forever to start up, then says cannot find guide data, then after minutes guide pops up, but will not play OTA, just endless spinning gear
not the first time, of course can’t play recordings either
time to give it a rest :man_raising_hand:
legacy is working like a champ.
Yep, mine is doing same thing. Worked this morning and now cannot load the guide data. tried rebooting Tablo and router. Did not work.
Not working on Roku or Android phone.
Same here. Gen 4 on Roku. They broke something.
Roku and iOS both out of action. Endless “Connecting to your Tablo” on Roku. “Unable to Load Live TV” on iOS.
No evening news for me.
Same here in NE Ohio. Seems Table 4th gen is down for the count across all apps (I have Android TV, IOS, and Roku.) None working.
Same here, “Unable to load Live TV.”
Rebooted modem, router, and Tablo. Does not work on Android, Apple TV, or Google TV
The good news is, it seems to be recording shows that were previously set up to record. To be honest, the evening news is about the only thing I watch live any more.
I think this was a temporary server crash (happens with Tablo a lot). About a half hour ago my Roku box (4802x with the just updated app) showed a blank live guide. My Android app said it could not load live TV either. Downdetector also started to spike with Tablo error reports. Then about 10 minutes ago both the Android and Roku started working again.
no wheel of fortune 2nite :disappointed_face::frowning::pleading_face::enraged_face:
but the recording will be there tomorrow if past experience holds
Mine is back up and running, too.
Sorry you’re having this issue. I’m not experiencing this. But, if you haven’t already done so, you might try restarting your router, Tablo, and Roku/TV in that order.
I’ve seen from @TabloTV that this is the best method when restarting devices. They may have an article on this, but I didn’t see it. This one only explains what to do, not how to do it.
Good luck.
Troubleshooting Connectivity Issues On the 4th Generation Tablo – Tablo
Edit: WoW, that was a LOT of comments that came in while I was typing. We’ve been watching our Tablo since about 3:00 PM CDT and haven’t seen an issue (in D/FW area).
Edit2: my Samsung phone isn’t showing the Home screen on the Tablo app, but the Guide and Library are working. The Home finally loaded after the Try Again was pressed.
working again…….
what ‘fixes’ such problems is to do nothing, wait it out IME
have gone to bed so often with bungled up tablo, then next day overnite it figured out how to work again.
reboots, restarts usually don’t help, IME
as a new user, I would do all that stuff, with middling results. got fed up. And it is physically difficult for me to get around between rooms to tinker with various devices, that’s why I have a tablo ITFP
so I learned to let it be, come back later, and usually the problem is over, and was not AFAIK on my end
and it does record as I set it up, one way or tother :slightly_smiling_face::+1:
Looks like I spoke too soon. Tablo crashed again on Roku with trouble connecting and no live guide (but not on Android, although it seems to be slow).
