Channel Different than what is expected
Has anyone seen this…I setup my Tablo 4 Tuner, all channels work fine (getting 135 channels and very impressed).
I live in the NY area and about 20 miles from the Signal and my antenna can support 55 mile range.
All channels work fine except for Channel 4.3 (NBC). It shows as NBC in the guide with the correct show at that time (I compare to my Verizon guide). But when I click the Channel to watch it, it shows WNJU and is a completely different program.
If I unplug the signal from the Tablo box and plug it directly into my TV, I see 4.3 (NBC) and when I look at the station in the TV, it works fine. Only on the Tablo is this single channel different that what is advertised.
I have opened two cases with Tablo and got round about answers. To date, about 1 year later, same problem, same issue with this channel…the rest work great.
You might be picking up the other channel from an overlapping area. That’s explained at the 2:30 time in the video. Watch the whole thing because it is informative. Changing the zip code on the Tablo might help.
AstroJimbo! Thank you for this helpful information…this is right on! Thank you again and Happy Holidays to you!
I’m also in the New York area. For me, NBC is on 4.1. 4.3 is something called American Crimes… or at least it was last time I checked. I’m not interested in true crime so I don’t have that channel selected.
WNJU is Telemuno and for me shows up on channel 47.1
I had the same problem, and the same non-resolution. I started a ticket, but I don’t think they are working too hard on it. They told me to change the zip code to a nearby one, and do the channel search again. That didn’t help me. Maybe it will help you. I live in the San Marcos, Texas area.
