Channel detail report doesn’t match channel scan
I just recently looked at the channel details report for my ZIP code (Boise, ID area). The channels on the report are all correct. However, the channel scan doesn’t match the report.
I would’ve thought the channel scan and the channel details report would receive their data from the same place.
@TabloTV - Do both the channel details report and the channel scan get their data from the same source?
What’s the channel report vs scan? My channel lineup that shows up when I do a channel scan is more accurate than what shows up in the guide data.
This is the link for the Channel Details report:
The channel scan is what you see when you scan channels in the Tablo app.
I’ve had the same issue. The report is great, but the channel scan didn’t always match and I had to try several zip codes nearby until I found one that matched. Don’t ask me why this is needed. The channel guide is the worst and doesn’t even match the channel scan for some channels for me. Part of the pains with Tablo.
Unfortunately, for me, every ZIP code in the area appears to have the same entries. It doesn’t matter what city I pick, I get the same incorrect sub-channel listings.
It’s just an annoyance because the major channels are correct.
For me, all nearby zip codes even had the major channels wrong. I had to find one closer to NYC for it to work and then later they started enforcing location services when you put in a zip on the app and I couldn’t put zips farther than a certain distance. Fortunately, I found one that worked, but a few of the non major channels are totally wrong and have with no or wrong guide data.
