Hi, is there a way to change the remote access port from 80 to something else? I am running a web server on my network that is already using port 80.
Doesn’t matter if some other device is using port 80. That’s totally distinct from port 80 on the Tablo device.
If you’re setting up port forwarding on your router, then you can use any external port you want, as long as you forward it to 80 on the Tablo.
Yea, doesn’t your web server have it’s own IP, separate from you tablo’s IP? Every device with an IP can have it’s own port 80 separate from each other… can’t they? or do you have some elaborate web server configuration on a funky network?
– or maybe I don’t really understand
This.
