CHANGE - ALL APPS - Single Channel Add/Scan
Feature Type
Change to Existing Feature
Requested App Platform
All Tablo Apps
Feature Title
Feature Description
The ability to add a single channel without having to perform a complete rescan which can take up to 15 minutes to complete (Guide Update). Perhaps an option to erase all other channels or keep them when adding the single channel.
The new channel can then be ingested into the ‘Optimizing Guide Data’ phase on the local device.
E.G. LGTV, DVR+, Stream+, Zinwell, Zapperbox, HDHomeRun:
I have observed that during overnight maintenance:
if a station has been scanned and saved in Your Channels and
that station subsequently added another subchannel:
That subchannel will automatically add to Your Channels without a rescan.
(Assuming the channel is already present in the exiting TCT.)
