CHANGE - ALL APPS - Setup show OTA channels only
Feature Type
Change to Existing Feature
Requested App Platform
All Tablo Apps
Feature Title
In Setup show OTA channels only
Feature Description
When I set up my new Tablo yesterday it said that 189 channels were found and I added 150. I have no way to see the other 39 channels because they are not in the list. Without counting by hand I have no idea how many are OTA vs Internet channels.
I would prefer it if that list is split between OTA and Internet channels. I would like to know how many channels my antenna found. I would also like to know if any of those 39 channels were left out because the signal strength isn’t sufficient with my current antenna. I have no way of knowing whether a better antenna would bring in more channels without buying one and testing it.
Hi @mdu,
When your run a channel scan, any channel without a channel number is a streaming one. Those that are not selected either have a too low signal strength or are duplicates.
To see more, check out this article.
Ater the channel scan, setting your Tablo to the Channels Grid View, may help.
