Chanels 24.1 to 24. All have 2 red dots
I have a bunch of stations that have red dots and cant watch evdn tough the scan picks it up. How can i get them?
You may be too close to the broadcast tower - turn off the gen 4 amplification, antenna not pointed at broadcast tower, need a better antenna, or ?
Go to the channelmaster utility(or use a different utility) to see if you can even receive the signals
Please share the channel listing from the ChannelMaster site so someone can give you advice based on your surrounding broadcast stations.
Or, use this RabbitEars.info Search Map and post a link to your results.
  1. Enter your address and ZIP Code OR just the ZIP Code in the Search box and click Search;
  2. Click the Move Pushpin to Center of Map View button;
  3. Press the big Go button;
  4. Copy and paste the Sharable link at the top of the Result List page into this thread and someone will check it out for you.
