CenturyLink
Hello!
Received my Tablo today and trying to setup the port forwarding since the router can’t auto-program.
I have an Actiontec C1000A.
On the router setup page, I enter the Tablo IP address.
The page asks for the STARTING PORT and the ENDING port.
My Tablo App gives me a PUBLIC PORT “->” PRIVATE PORT (I’m assuming that’s the start and end the router page is asking for)
When I click APPLY, the router page says THE PORT RANGE IS INVALID.
Any thought?
Your router should give a field for public port as well as private port as you’ll need to input both fields. The range isn’t the whole public to private ports, but should be just a single number. For example if you’re trying to port 8887 use the range from 8887 to 8887.
If you can it is also recommended that you assign a dhcp reservation for the Tablo ip address through your router.
According to the link below, if this is what your UI for the modem/router looks like then you cannot forward an External Port to a different Internal Port. This is an inherent limitation of your router.
My recommendation is your put your modem/router in bridge mode and use it as a standalone modem alone. Then get a new router. Even cheap $20 routers these days have proper port forwarding functions.
See links:
http://portforward.com/english/routers/port_forwarding/Actiontec/C1000A-CenturyLink/Minecraft_Server.htm
http://internethelp.centurylink.com/internethelp/modem-c1000a-adv-port-forwarding.html
