Did Tablo lose rights to these FAST channels? I was having trouble viewing them on Saturday so I did a channel rescan and now they just don’t show up anymore. Thanks.
Yeah, I’ve done a number of rescans….nothing. Also forced close app and restarted. Still nothing. My firmware and app are both updated to latest versions. I figured I’d try another scan later today. Then give up.
What do you mean, ‘check channel lineup updates’ ? How would I check those, except through a periodic scan?
Thanks for your reply though.
Here is a link to the current FAST Channel List. They do change every now and again.
Those ones are gone, as is MST3K.
My bad, you responded to my thread about MST3K. I’m still distraught as you can tell.
no problem
Sorry folks. Those channels are no longer available.
You can always see the full list here:
