After the update I noticed that captions in the Tablo app are now much larger than normal, they aren’t really centered, and they now extend beyond the edge of the screen.
I went into Roku’s settings, navigated over to the captions area, and every possible option that I could change was all set to “Default (set by content)”.
I can change the font, size, color, etc in those menus and I can see those changes reflected in the Tablo app, but the placement is still wrong and text still gets cut off on the right.
Gotcha. Thanks for testing/confirming. I’ll send this along to the Roku team to see if there’s anything we can do on our end to fix this.
It would be good to know what Roku OS build number you’re on (the four digits after the 10.5) just in case it doesn’t look that way on some other builds.
I tried all four 4k resolution options within Roku OS, and they all had the same issue. I tried 1080p and it was also affected. It wasn’t until I switched down to 720p that the issue went away. I was then able to change to any other resolution and the captions looked fine.
I’m not sure what the problem may have been, but it seems fixed for now. I’m hoping it stays that way!
2019 Roku Ultra LT. When coming out of fast forward, I see captions for a few seconds and then they go away, even though I don’t use that option. Only seen this with 10.5
