I try to get to recorded shows when there are 4 shows recording. I thought I read that I had 2 streams available outside the 4 shows recording, but I cannot get to recorded shows to watch. It just shows a spinning circle. I am using the roku app.
The 4 tuners you have also handle the encodering/decodering. At least one must be available to do playback.
-Rodger
The number of tuners your Tablo has dictates its capabilities.
Watching or recording a single live program requires a single tuner.
Watching a recorded program streamed to a device away from your Tablo’s home network requires a tuner. Watching a recorded program does not require a tuner.
Now that you understand what activities require a tuner, it’s easy to
do some ‘tuner math’. For example, on a two tuner model, you could
watch a show live while recording another. Or if you’re stuck waiting in
the doctor’s office, you can set a show to record and watch a show on
your tablet that you’ve recorded earlier.
On a four tuner model, someone can be watching the football game on
the big screen, while another person watches a movie on a tablet all
while recording two other live shows.
If you have 4 channels recording at once on a quad tuner, you should be able to watch a previous recording locally say on a Roku.
Can you try watching said recording on another device such as iPhone, tablet, computer, etc.?
If you are trying to watch remote then that would be a reason as remote viewing does require a free tuner.
When using tablo firmware 2.1.x and roku, the performance of retreiving the list of recorded shows was acceptable. With 2.2.x firmware the performance sucks gas. Especially when a tuner is busy.
There is a beta being worked now to fix issues with Roku and slowness
Just looked at the specs for the Vixs Xcode 5190 processor here, and see it actually transcodes 6 HD channels simultaneously. So I was mistaken thinking it was 4 channel only. Actually it really has quite impressive specs when you take the time to review.
-Rodger
True, but the Roku app can’t be used for remote viewing.
Correct but the Tablo can still only transcode 4 streams at once so if you’re recording 4 channels, you will not be able to transcode a 5th stream for say remote viewing of an old recording.
This may not be a hardware limitation but it is intended by design with how the firmware on the Tablo is written.
@Scott_Gaboury - We’ve had a few reports of this issue with Roku. Can you pop us a note and let us know which version of the Roku app you’re using and which Roku hardware you’re using as well as whether or not you have a subscription?
Yes, I did not realize they were talking Roku as that is not what was said in the beginning
