@TabloSupport can this link be edited and list a minimum router? Not all routers are created equally.
Also please suggest antenna that can receive BOTH VHF and UHF so others don’t make the mistake I made. Mohu Leaf WORJS for most but not channel 62 which is broadcast 13.
Omg! I never saw this in all the research I did on the tablo or during the set up. I mean I knew you needed the HD to record but not watch. I feel like an idiot lol. My understanding is that there really are no small antennas that will get vhf lo. The only ones that will get it are the big old school roof top ones because it needs to be big. Most stations no longer broadcast in vhf and those that do mostly are vhf high. Some of the new ones will get vhf high given correct positioning but none will get vhf lo. I happen to live in an area that has one of only 50 stations in the country still using vhf lo and I can’t get it (suburban philly). They say the antennas get vhf and uhf and hope you don’t catch them in the fib because fewer than 10% of the population is served by vhf broadcast and most ppl will never know the difference. This has been quite a learning experience for me. I can’t get Abc from philly ota no matter what i do because it’s vhf lo ch. 6. I can live with it given my savings
You are likely right that even a VHF indoor antenna will not get VHF Lo channels just cause the antenna is too small. But can’t hurt to try different antennas if you can get a channel you want.
There is a simple way of making a loop antenna for lo VHF. This person made a hi VHF loop antenna fitable in an attic small space:
The loop antenna for lo VHF would be larger but still manageable. Probably double or triple the size of the hi VHF antenna. One would have to calculate the size of the loop for the specific lo VHF channel wanted. This hi VHF antenna is 23" in diameter - extrapolate from that what the diameter size would be for the lo VHF antenna based on the channel needed (there is a formula and calculation to get the exact length based on the wavelength for that frequency).
These VHF loop antennas are quite powerful. I made one for channel 10 for a friend and it got him NBC at 100% (he is living in a forest 40 miles from the broadcast tower). The cost was about $10 mostly for the copper tubing from Home Depot. VHF antennas don’t have to be Yagis.
The loop is the important component. In the pictures above, the rest of the antenna is supporting structure for the reflector which doesn’t need to be as elaborate as in the photos.
Seems I got very lucky - picked up an RCA 751 on “closeout” at a big-box hardware store for $13. Hung it in the attic over my garage, and has been perfect for me, for all the channels I am capable of getting.
Yes I count that as lucky, I experimented with at least 10 antennas. I have purchased 2 antennas so far, looking to get a 3rd which may improve my signal in bad weather.
I know the feeling. I went through countless antennas over the past decade. I estimate that I had spent over $500 looking for the perfect antenna for my situation. I am in a valley surrounded by 50 foot trees. The slope of the valley contains many more trees. At the top of the slope there are even more trees. Altogether I am looking at combined tree heights over 75 feet. I tried every conceivable antenna that was hyped as an OTA “savior.” Even ordered antennas from Europe (the shipping costs were three times that of the antenna itself). In Georgia the trees never stop growing or multiplying…
I am glad I found this thread. I just got my Tablo 4 tuner yesterday and the WD My Passport hard drive that I’ve had for years wouldn’t work with it, which was a little disappointing, but not as much as the Tablo only streaming to 1 device at a time. So I’ve been trying to get the Tablo working before I invest more money in this setup and I was almost ready to give up, but apparently I can’t stream multiple live TV stream to more than 1 computer because I don’t have a hard drive attached. Would be nice if this was listed as part of the specs when purchasing so that others don’t spend so much time trying to figure out why it isn’t working like I did. In case anyone was searching for error codes, I was getting playback error response code 404. Maybe this will help other find this thread when searching as I found nothing on this site for response code 404.
My first drive was an older Passport and it was rubbish. It was just not capable of being used as a dvr drive. It kept disconnecting even when I plugged it into my Windows computer. I have a WD Elements drive now and it is working like a champ.
My recommendation is to get a bigger drive than you think you need. I have only a 1 TB drive and wish I had a bigger one.
PS: Pretty sure the specs do say you need a hard drive.
I ended up getting the 5TB drive that Tablo recommends on their drive support page. Seems to be working well now. I’m not getting the error anymore and can stream to multiple devices simultaneously, although it seems to have issues buffering frequently when more than 2 devices are streaming. I think this a Tablo issue because I have an incredibly fast AC wireless network, the Table is hard wired directly to the gigabit Ethernet port of the router and even the hard wired computer from the same router has buffering issues when other WiFi devices are streaming from Tablo. At only 1Mbps each, I don’t think 4 Tablo streams would even come close to crowding my network, especially the hardwired portion.
Works well enough though. My son is too young to know how to control his own TV, so I’ll have at most 2 streams going simultaneously for the next few years. I’ll have to figure out a solution after that.
I do notice the out of sync issue that I’ve heard others complain about since last October or so. I see it both on live shows and recorded media.
