I’ve had my Tablo Quad for about a week.
Now I can’t watch Live TV as I could watch the first few days I had it. I get the following error message:
Playback Failed. Storage is full. Delete some recordings before trying again.
With initial setup I installed and formatted a Seagate Barracuda 1 TB internal hard drive.
I was able to record the Super Bowl and 1 episode of 60 Minutes which is a total of about 6 hours. I’ve able to play these 2 recordings.
My Tablo tells me I have 970 GB available.
So I’m confused why I getting the “Storage is full” error message.
I have a TCL Roku TV. I’m using an ethernet cable between the router and the Tablo unit.
Any help from you all is greatly appreciated!
Do you have access to a Linux system? If so, you can connect the HDD to the Linux system to see if there is anything wrong with the drive. The side benefit of doing this is the logs that are not usually visible to us can be read when the HDD is connected to a Linux system.
