After typing in my network password, it’s just continually “checking credentials”. I am using my phone to try to set it up with wifi.
Do you have a computer you could use. Not sure about the phone but I know a Windoze computer will work.
I’m not much of a computer guru. I would have no idea how to do it through my computer. That’s okay, I was able to set it up through my Roku. Thanks for the help anyways!
Glad you got it set up. If you go to http://my.tablotv.com/ on a computer on the same network as your Tablo, you should find the Tablo and can look at all its settings.
Steve
Just say’n in case someone passes over this days, weeks or month later looking for answers - the web app is not platform dependent - PC & MAC
We Recommend
Any PC or MAC computer running Chrome or Safari with a sufficient video card for playing high quality video will work with the Tablo web app.
Works on really any OS, and other browsers… but for “support” purposes, particularly during setup stick with recommendations.
I’m having the same issue and can’t get it resolved. I’m trying to get my Tablo Lite device to connect via WiFi. When I go through the setup routine online, I connect to the Tablo WiFi, then choose my home network, which is an open network, no password involved, then it tries to find the Tablo device but just returns me back to the starting screen instead. I also tried using the app on my Android phone and it ends up saying, “An Unexpected Error Occurred. Wi-Fi Setup failed due to an unexpected error. Please try again.”
Unfortunately your network MUST be secured to work.
Could I set up a virtual wi-fi hotspot through my Windows 10 that uses WPA2 encryption to make it work?
This might work, but is not a tested or supported use case.
