Can't rewind or FF
I can record from TV but on playback it will not FF or rewind with my LG remote.
Bought another remote for LG but same problem.
Any suggestions?
Same problem here with my new Samsung Q90 TV. Waited forever for Tablo and Samsung to develop an app, but apparently they decided to skip fast forward / rewind capabilities. Simply awful.
Does it work by pressing the down button and moving the progress bar?
(edit: changed “cat” to “bar” – my bad!)
Use the directional buttons for now. Press up until the progress bar has focus then use left/right to skip 10 seconds at a time. It’s terrible and the video is dimmed while you’re trying to skip around.
If I need to skip more than a minute or two I’ll use my iPad or phone to skip to the part I want, pause it, then resume on the TV.
