I’ve re-scanned my indoor ChannelMaster Smartenna+, and I know it gets many channels. But since I picked my favorites for the Tablo guide, I can’t re-scan Tablo to display all the channels that I know the antenna receives. I disconnect, then am directed to the “Connect to Tablo” screen, and when I select the "Re-scan option it just instructs me to Connect or Delete. So, what am I doing wrong?
What you’re currently doing is a rescan to find other Tablo DVRs on your home network.
What you want to do is a channel rescan from the Settings screen in the Tablo app.
OK, thanks. I was not scrolling down far enough on the Settings menu, but I found it. All is good.
