Been using a Legacy Tablo for 7+ years, and bought a 4th gen to try it. Why will it not let me set a recording for the FAST channel “Sweet Escapes”, specifically the show “Holiday Baking Championship”? On a Fire TV, it says to contact Tablo CSR, and on Android a click to record does nothing.
Also, why are there 5 FAST channels in the guide above the local OTA channels (ion, AMC, Sweet Escapes, Cheddar)?
Sweet Escapes is a Warner Bro. channel. All the WB channels are watch live only, you can’t record them.
Why they are on top is because they are channels Tablo is promoting. Whether Tablo is getting compensation for these or not, I have no clue.
Make sense to me (but the wife is not happy). Is there a way to tell which FAST channels can’t be recorded, other than just try and fail?
If you look at the channel icon, there is a small yellow circle with a WB inside. Those are the ones that you can’t record.
Thanks! I just found a reasonably complete list of the WB channels, in case someone else in interested:
