Can't get Tablo 'Connect' to work
I have a Tablo Gen 4, Firmware 2.2.54. I turned on UPnP on my router and rebooted. Doesn’t work on my Android phone.
Is there another way?
What are you trying to do with PnP against the Tablo? Remote Access?
The 4th gen Tablo does not support Remote Access.
