Well is the WiFi network on the new router the same name and password as the old network? If not, then you need to change the Tablo settings so it can connect to the wireless network on the new router.
New SSID, New password.
Well your Tablo won’t connect to the new SSID without telling it what the new password is. Follow the guide below.
You might find this helpful too. If you can’t successfully change the WiFi settings, open a Support Ticket for help directly from Tablo Support.
Thanks man. None of this is working. Gonna open a ticket
