Hello, this has been an ongoing issue for months now. At first I couldn’t delete one show from a series but now it has finally deleted and the TV show icon is still in my recordings on 2 ios devices and an Android (main device to TV) as well as the WebApp. Can someone help get rid of this annoyance please? I have seen other threads on this issue, nothing I saw on those seems to work for me. I have rebooted several times, both my devices and Tablo. I cleared the cache on my android device and even deleted the app and reinstalled, still there!
I’ve had this in the past and it’s actually a problem with the Tablo database. Open a ticket with support and they will have you put your Tablo in remote access mode, once they get in they can correct the db problems and it’ll go away.
I’ve had this happen in the past under these conditions:
- Scheduled recurring recording of a series.
- Series episodes were recorded.
- Removed channel series was broadcast on.
The result was phantom recordings I couldn’t delete.
I was finally able to delete the recordings, and have their icons removed, by re-adding the channel the recordings originated from.
I also unscheduled the series from recording section, before removing the channel once more.
Thank you, I thought that might be the case.
