Can't access recordings on drive, Legacy Unit
Hi,
On my legacy setup I can’t access stored videos. I just started getting an error saying it couldn’t access the video.
Since that model uses an external drive, I installed EXT2 volume manager on my Windows PC and it can access the drive. I see all the folders and it will let me open all of them, except for the REC one. After a fairly long wait I get a CRC error.
Does anyone have any experience with fixing that?
This might be a power supply issue. I suggest checking out this article, which may help:
If that fails, don’t hesitate to contact our support group:
https://tablotv.com/support/#contact. They can help you with further tests to determine what is going wrong. If there is a drive issue, they have tools that may be able to help.
