I don’t believe this to be a Tablo issue but rather something else. A couple of days ago our ABC affiliate channel won’t tune in. This is happening both on the Tablo 4 tuner and an HDHomerun Extend. Neither one can stream the local ABC affiliate. They both get an error. The HDHomerun’s error mentions that the Audio stream is not available but doesn’t show the video or audio. The Tablo just says cannot view this channel. However this is only happening on the main channel 12.1. The sub channels come in just fine. 12.2, and 12.3. Rescanning the signal shows 5 green dots for the main channel and the sub channels. I’m using an Antennas Direct Clearstream 4V with a Winegard LNA 200. The system has been up and running for over a year with no changes and the error just started showing a couple of days ago.
Any idea why the main channel would be giving me an error but the sub channels come in fine.
Here’s the really weird thing. It’s only happening on my FireTV Cube. My 2nd gen FireTV box works fine. It also works fine on my FireTV stick and Roku Ultra. Makes me think that the Cube has a problem. Seems like other people are also having weird issues with the Cube from what I’ve been reading on different forums.
Tried it on both…But like I’ve said before, I’m sure it’s not a Tablo issue. It also happens on my HDHomerun. I have a ticket in with Amazon as I’ll bet it has to do with the Cube.
Indeed - I would still bet it’s something funky w/ the broadcast parameters that the broadcaster is sending, but it’d be interesting to take a closer look on our end to see if we can see exactly what the problem is.
Amazon likely won’t be able to see what’s triggering their codec to choke and will tell you to bother us instead
