Hello! new user here and excited to use my device… just cant get it to connect…
any thoughts?
it’s a 2 tuner, using wifi (tried it with ethernet, no lights on port but the device is on the network). I can see the device inside the app, when I click on it it says connecting, but never goes past this. rebooting, factory reset, total power down, all with the same result.
help?
