I’ve lived overseas for 7 years and now I’m back, living in downtown Ottawa (Sandy Hill actually). I’ve had it with Rogers and am planning my switch to TekSavvy. Now with SlingTV (I have an Tomato’d router with Astrill VPN that I used while living in China – anyone else using SlingTV in Canada with VPN?) available this is doable. I’m ready to cut the cord. Tablo looks like the solution for local and network TV.
If the Tablo is wired to your router, you can stream to up to 6 devices at the same time. Recording a show or watching a live show uses a tuner for each one, while watching recorded content does not use any tuners at all. So you could watch four different channels at the same time if you wanted to.
Our awesome users beat me to it so I’ll throw this one out (again)…
If you have any other questions, let us know.
I just figured if I had 4 things to record I’d watch TV like normal - via the TV! That’s a rather novel idea, I realize, but TV’s do have tuners so you can stream to your heart’s content and watch TV on every set in the house and garage since they also have tuners.
I live in Ottawa across from Camp Fortune OTA and no way 14 channels - just the 4 English - CTV, CBC, Global & TVO. I didn’t select the French channels - maybe 4 as well. The NV20 antenna was designed for Ottawa. I have 2 NV20 but for TABLO use a Winegard amplified flat antenna. You might consider NCF as service provider. I just have the 2 tuner. Also need a USB hard drive to use more than 1 tuner. Four tuner model needs a strong signal. Internet is used to update program guide. Not a good idea to put TABLO in unheated environment. Some families get a TABLO for the kids and another for the parents - each unit has it’s own name. Only 1 schedule subscription covers both.
You can put an antenna in your attic but putting your tablo and disk in the attic isn’t a good idea because the attic environment is outside the range for disk drives, especially in summer.
Depending where you are in Sandy Hill I doubt your will pickup the channels from Herbert’s Corners in Manotick with an NV20. You should get the Camp Fortune channels minus maybe Global. Again it depends on whether you are in the low or high part Of Sandy Hill. A roof mounted 2 or 4 bay antenna should get you all local channels.
