Once I get the app working at home it’ll work for a day or so and then I get
This happens whether I am home (on local network) or not. Even remote reboot doesn’t fix it. I have to be at home. Delete the tablo and re-add it. It’s been like this since day #1. It has never been reliable. I’ve tried everything from multiple routers to new tablos. Yes it has a static IP. Yes it works with all other apps IE: Apple TV.
Anyway. I don’t expect a fix. Trying “use full site” in chrome still doesn’t play the stream and if I’m using safari there is no reason why it should ever try any Android specific protocol.
