Can’t find tablo
I’m getting unable to locate your Tablo. I unhooked the Ethernet cable earlier from my router. Had it unhooked for couple hours. Connect the Ethernet back and changed apps from Netflix to Tablo. Got the unable to locate your Tablo. So I pushed the button to flash.
Is there anything else I can do?
