For those of you who have been frustrated like me at the frequent “can’t connect to Tablo”/“can’t find Tablo” messages when using strong WIFI to connect because the modem Ethernet is in another room, I finally found a solution that worked for me and hope helps others. I bought this:
TP-Link AV600 Powerline Ethernet Adapter(TL-PA4010 KIT)- Plug&Play, Power Saving, Nano Powerline Adapter, Expand Home Network with Stable Connections Amazon.com: TP-Link AV600 Powerline Ethernet Adapter(TL-PA4010 KIT)- Plug&Play, Power Saving, Nano Powerline Adapter, Expand Home Network with Stable Connections: Computers & Accessories
It creates an Ethernet connection using your wall outlets plugs. One wall outlet Ethernet cable goes into the Tablo Ethernet port, the other wall outlet Ethernet cable goes into your modem. No set up - just plug and play. Problem solved! No more “can’t find” messages on Roku, iPhone etc. I bought a couple Cat 6 Ethernet cables separately to make sure it was carrying good speeds through it but comes with 2 Ethernet cables (not sure if Cat 5 or 6). Hope it helps!
