Is this possible to connect two iPads to Tablo? I want to transition to a new iPad without losing recordings
Yes.
The recordings are stored on a hard drive connected to your Tablo.
Every device, like an iPad, Roku, … can access the recordings on the Tablo’s hard drive.
@Mniszewski - Yep, no worries about that as @Radojevic mentioned.
Just download the Tablo app on your new iPad and connect to your Tablo. The first sync may take a bit longer than normal (it’ll be syncing ALL of your data vs. just some) but once the sync is complete, you’ll be good to go.
