I will be travelling to London and would like to have access.
Has anyone tried this? Issues?
Thx!
Will
Thx!
Will
Depending on what device you’re using to access the Tablo, it works fine. I’ve accessed mine from Singapore and Bali.
If you have it set up correctly, then yes… Check out the user-supplied picture on the feature page:
No issues from France, Italy, England or the Bahamas for me and Tablo remote!
Doing it right now.
Incidentally, no issues with 50Hz overseas versus 60Hz in North America.
Of course just make sure you have a plug adapter if your USB is powered from the wall rather than a TV USB power port. And, of course, make sure your connecting device has been paired at home with the Tablo before you go overseas.
Happy travels!
The device you are watching on MUST be paired because after 3 YEARS, @TABLOTV STILL has not got a log in / password instead of the pairing thing. I hope login / password is coming SOON.
