I know it’s been mentioned here before, but it’s made the news again. https://www.yahoo.com/tech/s/comcast-twc-cablevision-53-box-save-money-144223727.html
Actually if you can afford the difference, I recommend TP-LINK Archer C7 AC1750 Dual Band Wireless AC Gigabit Router, 2.4GHz 450Mbps+5Ghz 1300Mbps, 2 USB Port, IPv6, Guest Network
@beastman - You’ve kind of mixed apples and oranges in your post:
The article is about a TP-Link cable modem, and your recommendation is for the Archer C7 Router (I’m using the Archer C8)…
Agree with you that the TP-Link Archer series are good routers, but you’ll still need a modem as well.
Yes I mixed. I actually have a Zoom 5341j which i’ve had over a year
