Hi
I don’t believe Tablo is integrated with Roku search… it’s somewhat of an apple vs. an orange thing. Hulu and Neflix and the like are ‘static’ content, whereas your Tablo is whatever you chose to store.
Any searching has to be done from the Tablo app itself (for now).
If you have Rokus connected to all your TVs, then you will be able to use you Tablo on all of them via your network. You still need a PC or tablet to set up the Tablo for the first time.
On other platforms such as Nexus player, this is def feasible, but the Devs have to use the built in google apis to do it. For example Plex on the Nexus player is integrated with global search, and voice search. Its pretty amazing!
@PiX64, oh yes, it can be built, but might be sufficiently hard. Most searches are built against a centralized server, even for user specific content, but in our case the dbs are located on little boxes everywhere… which is why I say it’s sufficiently hard.
(who knows, it might not be hard at all… I’m making a lot of assumptions about the api, maybe we just proxy once via my.tablo.com and go… or maybe the api has some kind of local net capability… but I doubt it… too many variables).
@snowcat I used an Android phone to set up my Tablo, not a tablet or computer. Of course the point is you do need something.
