When viewing a live TV channel via the web app you can adjust the volume of the broadcast using the volume slider. The volume slider, when the channel first loads, is always at 100%. If you reduce the volume to 25% and then switch channels the volume returns to 100%. This bug can be very annoying especially when you need to keep your environment quiet.
@hellbound - Thanks for reporting. I’ll send this over to the team and see if there’s something we can tweak to keep the sound consistent.
