We just bought the guide subscription. It shows in my account but not my tablo app. I’ve tried reboot g to no avail. What am I doing wrong?
Probably nothing.
You might have to wait for the guide to download, etc.
That could take a little bit of time to download the guide data/sync.
Under settings, what does it say under SUBSRIPTIONS?
You should see a little progress/percentage meter.
~RF
I don’t see a ‘settings’. I’m using Roku, does thatmatter? (Thanks for your response!)
have you add your tablo serial # after completing your payment?
Yes, I did.
In your tablo UI, under settings does it show you have a subscription and have you click refresh?
In your web browser (phone or computer) log into your Tablo with the credentials you used to sign up.
Log into your Tablo here: MY TABLO
Click on the three lines in the upper left hand corner and select SETTINGS from the list.
You should see the status of your guide data/etc.
It should take 15 minutes to an hour.
I’m sure you just need to wait a bit.
~RF
Thanks RF, it is showing, now, an active subscription and is downloading the guide. I’m still new to this and I guess I expected immediate access!!!
It can sometimes take your Tablo, our servers and our subscription portal a little bit to connect all of the dots.
