Thanks to all the input here I bought a Tablo. This, after trying Plex DVR and HDHR DVR. Tablo is clearly the best for me.
One question- Is it possible to set recording defaults like how many shows to keep, channels, new / all? So I don’t have to set them every time I set a recording? If so, how?
Thanks for your purchase @SJMaye! Glad to hear we won the bake-off
Yes, if you have an active subscription you’ll have access to all of our advanced recording features including keep X, channel select, and Rec New/RecAll.
Yes, so I have been using the advanced settings all along. The recording defaults I was used to were from my Tivo You have defaults that you set such as the one channel or all, number of shows to save, padding etc. This makes setting a record a one button click unless you wanted to change one of those defaults.
No problem, though. I am very happy with what I have experienced so far. The channel reception is actually better than it has been with the HDHR Extend.
Can someone tell me if what I am seeing is normal? I am supposed to have 2 weeks of guide data, but when i look at the channel grid guide and attempt to look forward in time I can only go out 24 hours ( I think that is the number).
