I purchased my 2 tuner Tablo from Best Buy back in Oct 2023. Today I noticed that the blue light appears to be OFF. I rebooted/reset the Tablo and checked the LED setting which is ON. If you get up close, you can see the blue light is on (?) but very dim and when you step back you can’t see it.
The Tablo appears to be working but I’m concerned that something is going on.
I’ve contacted Tablo support and they are looking into it.
I have a similar problem, which I posted on April 3.
I have a gen 4 4 tuner, LED always on and visible from across the room, which is my preference so I know it is on.
Gen 4 2 tuner LED was OK when new, as bright as the 4 tuner. But then the LED went completely off. Every now and then it will turn itself on very dimly for a day or so, then turn itself off again. I have had roku and IOS apps setting for LED set to on since day 1 and just checked, they are still all “on” for LED, but no LED to be seen today. Maybe a dim one tomorrow.
I am sure to get an eye roll here, but I’ve been dying to ask:
Have you toggled the switch off and back on to see if that changes anything? I remember a firmware update giving me a similar issue way back (I had the light off, the fw turned it back on, but settings showed off…)
Yes, in fact a few times, but no change.
The LED is not necessary for me to record etc., maybe it will fix itself. Not worth the annoyance of a warranty claim or lots more troubleshooting.
I tend to disagree. What we may be dealing with here is the beginning of unit failure. With a one year warranty it’s best to determine the actual cause rather than accepting this as a minor inconvenience.
OK. For me, not worth it. I have a 4 tuner that I bought after figuring out the 2 tuner was not enough tuners and that’s what I am mainly using now anyway.
If the LED acts funny but the unit still works, I’ll live with it.
Plus,it’s maybe a year before I move on to another box, one that is next gen and DRM capable, of tablo brand or another. Gotta admit the Zapper is enticing, so I should start looking at the forums for it.
I think this LED thing is a QC problem. YMMV but I cannot remember the last time I owned an electronic device that had any QC issues at all. OTOH there also have not been many posts here about the LED, FWIW.
Could be simply over-driving the LED current, causing it to fail. Had an AV receiver with a light in the volume knob. Kept burning out. Measured current to it, and it was WAY over. Put in a resistor and it lasted much longer. Can’t do that with most modern devices as I assume the LED is surface mounted and just points at the window, with maybe a plastic “guide” to aim the light.
The blue light went dim on my Tablo 4 today. Reset the device, unplugged the device to reboot, reinstalled the app on the TV and phone - nothing works. The unit is 14 months old. We’ve had nothing but issues since day one, and this is just the latest. The latency is awful, both on the TV and phone. Contacted customer support - spoke with two reps. The first rep was less than helpful. The second rep said someone from Tier 2 would contact me via email within 48 hours. Very frustrating.
I also noticed this morning that the blue LED is off on my Gen4 too. I use the Roku App. Looking in Settings, General, LED says it should be ON. I rebooted the Tablo and during power up I did see one short white LED blink. Other than the blue LED not working, the Tablo is working properly.
I was having an issue recently, as of 4-5 days ago where my light was not working even if toggled on. Had been this way for a few weeks. I noticed over the weekend it started working again for no particular reason. The only thing I did was a rescan of my channels on Saturday evening through my Roku device. It’s in another room so I don’t know if related since I didn’t see it until next day.
I have the same problem. I tried resetting in settings switching to off, dim, and back on but the light stays off. I have been having several other problems, the latest is in Library sometimes after selecting a recording to watch, Tablo closes and you have to reopen the app. Sometimes when deleting a program the app closes out, Then there are times that the video freezes but the sound continues, if you try pausing or rewinding it appears to be at the end of the program. You have to close out of the program, reselect it and fast forward from the beginning to where you left off.
