Big Feature Request
The best new feature you can possibly add would be able to view recordings from a web browser on a local computer.
@davidrap
Not sure what else works but I’m using Blue Stacks 5 to run Tablo on my desktop and it works. Probably others out there too.
thanks not looking for paid software
It was free
not according to the website
My final comment… Google it…
Blue Stacks 5 is free to download and use, functioning as a freemium Android emulator for PC, allowing you to run mobile apps and games with some ads and optional premium features for an enhanced ad-free experience. While the core emulator is free (Freeware), some extra services or removing ads might involve costs, but the basic app runs without payment.
Key Points on Cost:
  • Free Core: The main BlueStacks 5 software is available at no cost.
  • Ad-Supported: You might encounter ads within the platform, which is how they offer it for free.
  • Optional Premium: They offer premium subscriptions to remove ads and potentially get other benefits, but it’s not required for basic functionality
On Linux I run Waydroid as an Android emulator. It runs great.
Just download it and try it… I use blue stacks and its free and it works. I guess the tinkering days of us nerds are far and few between.
I use Bluestacks Air on my Mac and it works great and is free.
i tried but when i find my tablo it says its not connected to internet
I wonder if it’s because I have my Tablo on Wi-Fi and not direct hook-up?
On w10/w11 you can use mustardchefs was builds Releases · MustardChef/WSABuilds · GitHub
Has arm and intel builds
Get gapps build and install latest app.
