Best Indoor TV Antenna, Expert Advice to Choose
That’s a good observation @CarbonCompound ,
We used to have a mention of TV Fool in the knowledge base; it’s since been removed. We’ve also tagged support to ensure agents don’t mention it.
Perhaps that is a more recent change?
April 6, 2026
That would be an agent using old data outside the knowledge base.
We thought all mentions of it were removed, that particular one is getting fixed.
Thanks!
Let me be the last to apologize. Sorry about that @moe313. I’ve seen the same things as @CarbonCompound and reported a few in the past. I just jumped the gun. My sincerest apology to everyone, too, for causing a stink. This won’t happen again.
I have the ClearStream 4V antenna installed in my attic. I can get around 60 channels. Highly recommend it.
If this one doesn’t work it is doubtful any indoor antenna will.
This is the one that I’ve been using for the last 4 years. It’s versatile enough for RVs but small enough for indoor use. If you don’t have VHF you don’t need the crossbars.
Mine is outside on a 30’AGL rooftop mast.
I’m fat, lazy and fairly stupid… Omnidirectional means no climbing or pointing or falling… Rolling around in the flowerbed shouting profanities.
Thanks for your guidance, it really helped me make the right choice. With your advice, I was able to pick a reliable and good indoor TV antenna that I was looking for. I was a bit confused before, but your suggestions made things much clearer. Now I’m confident I’ve bought something that fits my needs perfectly. I really appreciate your help!
See?
Maybe I missed some?
Joshua here, in Boston. The rabbitears report point is the one worth stressing — without signal strength, distance, and terrain data, any indoor antenna recommendation is just guesswork. I’d add that the report also shows which bands your local stations use, since VHF-high needs a different element than UHF, and plenty of compact indoor models skimp on VHF. Posting that first saves everyone from suggesting something that won’t pick up your actual stations.
Thanks for your contribution @joshuawhite, and welcome to the community. Most regulars here know this, but some new users either don’t know how to do this or may not want to share their location, even though RE.info drops the location accuracy on shared links of specific locations.
I think it sometimes boils down to wanting a quick-and-dirty way to watch and record OTA stations and if their station reception isn’t great out of the gate, fine-tuning their antenna and network is sometimes a bridge too far for some users.
I’m wondering if those links are still available?
The point about the rabbitears report is the part worth focusing on. Without knowing signal strength and tower distance, any recommendation is basically a guess, and buying an antenna before checking that seems backwards. I’d add that indoor reception also depends heavily on where the antenna sits in the room and what’s between it and the transmitter, so even a good model can disappoint in the wrong spot. Posting the report first gives people here something concrete to work with instead of guessing.
Hmmm.
Tag as spiced ham. Mmmm
The point about needing location data before picking an antenna makes sense. Without knowing signal strength and distance to towers, any recommendation is just guessing. Posting a rabbitears report gives everyone something concrete to work with. In Portland, terrain and distance can vary a lot block to block, so one setup that works for a neighbor might not work elsewhere. Better to start with real data than buy blindly and return something later.
OMG, are you related to @EmilyJones?
They joined just to post that response
