Best Hard Drive for Tablo Quad
And I thought I was a hoarder almost filling a 4TB drive. Yours is truly impressive.
Does your Tablo have any trouble managing that many recordings?
Note to consider, as you just had one drive die. Often discussed, using your DVR as your digital media library.
All your content is stored on a single, semi-proprietary device. There’s no native backup or portability. That’s not to say it isn’t possible, not inherently supported.
More space means a larger collection to loose all at once.
The ext4 file system used by tablo can support a volumes/disks up to 1 Exibyte - Ext4 Howto
Ext4 adds 48-bit block addressing, so it will have 1 EiB 1 of maximum file system size and 16 TiB of maximum file size for 4 KiB block size.
Certainly some shows/movies must be part of your collections?
Now, I believe I’m stocking up for retirement… when I may need to cut streaming services and, I’ll have hours/weeks/months of show to watch. Is it really hoarding if you can justify things?
No tribble at all.
I bought this 5Tb one. Now I have 12 tuners and 12Tb storage as I have 2 Tablos and a TiVo. I am planning to sell one or the other.
Amazon.com: WD 5TB Elements Portable HDD, External Hard Drive, USB 3.0 for PC & Mac, Plug and Play Ready - WDBU6Y0050BBK-WESN : Electronics
