It’s 12V with same barrel (5.5mm OD, 2.5mm ID, Positive center) but it is 2A opposed to Tablo’s 1.5A. That’s okay, the device only draws the current it needs.
It’s a bit bulkier and it is black opposed to white, but I can confirm it works.
Unfortunately it’s out of stock but the voltage, barrel, and at least 1.5A is what matters if buying a backup.
That’s beefy! The USB 2.0 port still can’t exceed 0.5 amp by spec. That’s the limit unless the Tablo and hard drive exceed spec. That may not be a problem on some hard drives. Some of the small 2.5 and SSD can stay within an acceptable limit though. I would be interested in seeing what a power meter said.
Yeah, using a beefier brick won’t increase the power capabilities of the USB port unless the stock power brick was under-spec but I doubt that’s the case.
