Seems like we really need a backup app setup for Tablo’s Hard Disk. I have been using my Tablo for less than a month now, and my 1.5 TB drive is about 80% full. With 4 tuners churning away, it gobbles up the HD space quickly.
In this forum there are three documented methods of getting shows off your Tablo. Look for tablo2go, SurLaTablo and a VLC plugin.
Yep - and there’s a whole boat load of people here who use PLEX and know how to fairly easily do this… and with those “3rd party” apps luker listed, it’s not hard at all. (I can get recordings off mine so anyone can do it)
Yes there are 3 different utilities floating around to let you do this. None of them are officially supported by Tablo of course.
@marjamar - Download for offline viewing/storage is definitely on the to-do list. We’ve been a bit preoccupied over the last little while with Roku/Amazon/Android TV but once we’ve got those crossed off the list, we’ll be looking at what’s next on the roadmap. I’m hoping this will be one of the priorities.
Thanks for the helps.
@marjamar - Download for offline viewing/storage is definitely on the to-do list. We've been a bit preoccupied over the last little while with Roku/Amazon/Android TV but once we've got those crossed off the list, we'll be looking at what's next on the roadmap. I'm hoping this will be one of the priorities.In the meantime, as folks have pointed out, our users are super smart and have figured out a few alternatives.
I see you posted the same time I did. I do appreciate that there is a way to ask for features to be added, but I really don’t think we should be asking for this, it should have been included with this unit. To bother to do recordings, in all that it takes to review, setup, resolve conflicts and all that goes into recording, must mean we really want these recordings. That being the case, it must also stand to reason we don’t want to lose them simple because our HD gets full and there isn’t a way to conveniently backup and clean up our HD. To me, this is one of those “no brainers” we’re all heard about.
@marjamar, name another DVR that does this. I can’t think of any, so saying this is such an important feature is really pushing it.
+1
Snowcat is right per usual.
My 2 tuner Hauppauge does this. Actually, I was surprised there wasn’t a built-in way to do this with Tablo. And yes, this is a very important feature – Unless you do not really wish to save your recordings. I do.
@marjamar, what standalone DVR of Hauppauge are you using? (just curious)
I’ve owned their frame grabbers and tuners, but never one of their DVRs.
I’ve had a few of them. The one I am talking about now is the Hauppauge HVR-2255. It works well, but the tuners are not as good as the ones in Tablo, but the recordings are a bit higher quality. There are also a number of settings that can be used to gauge quality against filesize.
The HVR 2255 is not a standalone PVR. It uses a computer. You are comparing apples and oranges.
TiVo which is like the gold standard of PVRs does not even have the feature you request.
You know, to say something is “really pushing it,” because other DVRs don’t do it and “that is just how DVRs work,” is not that compelling or strong of an argument. There have been millions of things that didn’t exist until someone invented them and the fact that they didn’t exist before they did changes nothing. Backing up data is something that IT specialists constantly admonish people to do. Why shouldn’t people want to being able to back up their recordings.
Thanks for the current post to this topic. I was looking back when I posted here, and man have things change! Backup issue is all but gone for me, had some rough sailing for awhile (still do in a couple areas), but overall, I am good now. I do hope fully stability comes to Tablo and I really would like some 5.1 surround sound, but most of what I really bought the Tablo for is now a reality, so I’m happy.
-Rodger
My argument back then (7 months ago) is that backing up recordings is not an absolute must have for a DVR system. If it is, then the Tablo is the best DVR in the entire world, since you can back up the Tablo pretty easily using a multitude of tools written by the community here. No cable/satellite DVR nor Tivo can do what the Tablo can when it comes to backups.
