My cool-running Tablo decided to quit working via Roku (Premier Plus) today. We watched TV earlier w/o any problem and then this evening the Tablo would not connect. Nothing was changed anywhere. The Roku sees it, and then when a connection is attempted, a (dark) blue screen of death appears, stating “Authorization failed.”
Tablo and Roku are hardwired and on the same home network.
I rebooted the Tablo and then the Roku, same problem.
I can access the Tablo via my Android phone via Wi-fi.
Googling this term and searching here it appears no one else has had this problem, so I’ll be the Guinea pig on it.
Side note, it keeps trying to update to the 2.22.22 firmware and it never does. It is running the .20 FW version.
I’m having the same message appear, but only on my roku devices. This started immediately after updating to the latest firmware. The web based application on a computer works perfectly fine. I’ve tried rebooting the router and the Tablo and have deleted and reinstalled the roku app. None of that works.
I’m having the authorization failed message appear on my roku after allowing an update to .24. It started Tuesday (nov 27). I rebooted everything (knowing tech support would ask me - I thought hard resets went the way of ms/dos and windows 3.1). It went away on Friday (mysteriously after tech support asked me to reboot my device) but came back Sunday (Dec 2). I’m not happy. What kind of authorization is it seeking? It doesn’t ask me for any credentials. It was working fine until the update.
I’m having exactly the same problem. By chance, my internet has been out since Saturday morning and since then I get the same error: authorization failed. Roku (x3 of them) are local to the Tablo. Using my cell for this. Tried iPad iOS app and having no problem.
@ltldevl Try rebooting the Tablo - we’ve seen this do the trick in most cases. @user_293 If you’re still experiencing this failure, can you reach out to our team? We can take a closer look and see what’s up.
Ive been having the same problems since before Christmas. Ive had many hours of frustration trying to fix this issue. Trying all the above. I luckily also have a Fire Tv Box so today downloaded their app and guess what? it works on theirs. So it must be a Roku App problem. Fingers crossed it keeps working on Fire Tv. Lets also hope we get a remedy for Roku App soon as not everyone has other options like me.
