I assume the below-pictured circle icons indicate signal strength for that channel. Does anyone know if they are dynamic - as in do they update periodically by themselves (page refresh okay), or does it only capture signal strength when I re-scan for channels?
A dynamic indicator would be most helpful as I’m trying to configure my antenna (it’s a struggle to get channel 8 and 13 at the same time).
Dynamic would mean more processing power and work for the unit… unless you are in a fringe area how often would it really change unless you have an indoor antenna that’s sensitive to being moved.
Maybe some would use it but having lived here for 20 years I’m pretty sure of what channels are where and how far we are, etc.
The Tablo tuner/receiver is pretty solid from what I’ve seen so far and can easily get anything any other device can get for us.
Nope. Signals bounce. Your compass can tell you what direction the tower(s) are. But what you want to know is what direction do you get the best or most channels. That could left or right of the tower’s direction.
Or maybe you want to balance to get stations that are in different directions “as good as you can”.
And maybe your antenna is not sensitive enough, or maybe you need an amp. The best way to determine these things is to survey what you get in several different positions.
Different types devices solving different types of problems… the HD Homerun devices are really only “live tv” … there is no native built-in recording capability or channel guide… for that you need a 3rd party bit of software and a computer to run that on… the TABLO is a complete standalone DVR solution (which is why I am using it rather than a media center PC or using software on my desktop to record the hd homerun stream)
