Apple TV HomePods not working
Beens weeks (months) since this issue was reported. Any update on the fix? I don’t believe anyone is even working on it at this point.
They aren’t even going to fix it. They see the solution as don’t use the HomePods and use your tv speakers.
Thank you for contacting Tablo Support. We apologize for any inconvenience you have experienced.
To resolve the issue, please follow these steps:
Delete the Tablo app from your Apple TV.
Change your Apple TV audio output setting to internal speakers.
Restart your Apple TV device.
Reinstall the Tablo app from the App Store.
Please let us know how it goes or if you need further assistance.
Best regards,
Robin
I believe what they sent you was a workaround, not a resolution, so you can continue to use your device without the HomePods until the fix can be implemented. That should have been clearly stated in the email. I also believe that they will work on a solution, but it may take much longer than you think. They’ve been pretty good about fixing such issues in the past.
