App stuck on location request
Unable to connect Tablo this morning via Roku or app on iPhone. Did a soft reset with no luck. Did a factory reset next. Now setting up using the app. Acknowledging Wi-Fi setup and password. Now constantly stuck on location request. Kind of stuck. Settings on phone set to allow location to apps. Thanks for any suggestions
Based on other current posts, there seems to be a Tablo outage
Are you aware that you now will be unable to view anything that was on that drive – and that you’ll have to reformat it to use it?
I do. Was working fine. I’m hoping it’s a problem due to the outage that others are experiencing
Okay… :).
It just breaks my heart when people go to that extreme and then they discover 5 min later that:
a) it wasn’t their tablo
b) they’ve lost all their recordings
I’m glad to hear you’ve looked into this first!
Yeah I lost my recordings but it’s ok. Nothing on there I can’t live without.
