App connection to Tablo
My Tablo is ethernet connected to my router. I am currently watching a live ota channel via the Tablo. The guide is working. When I open the Tablo app on my smart phone, the app goes to the "connect to internet page. Is this normal?
If you’ve cleared the cache and data on your phone, then yes. Otherwise, I would think not.
Wait…what is “connect to internet page”?
The page where you select “connect by WIFI” or “connect with Ethernet”. I found that my phone changed to a different network. Changed back and that fixed the problem. Thanks for responding.
