I am having trouble getting the script to work. I am running it with the ip addy of the Tablo and the -list flag (obviously incorrectly or I wouldn’t be posting )
@gradman2k3 , you are using an older version, try downloading the most recent from https://sites.google.com/a/moboard.com/tablo/ - -list was not an option in the first. Hopefully that will help clean things up.
Thanks for the info. I just clicked on the top link stupidly assuming it was the latest version. I’ll grab the latest one and give it a go.
Thx
@BoomerTheWeimI'm trying to post process the tablo2go with mcebuddy. i'm having some issues with the metadata being way off (season # results in 56 when it should be 3 for example, similar issues with episode #'s) and i'm not sure if its because of the way tablo2go names when the mce option is selected, if its because I'm using the mutagen option, or if my problem lies in the mcebuddy process. I noticed you made changes to the 33 version. I"m using the 56 version of tablo2go. Did you have a similar problem? Also, what's better to input to mce? .TS or MP4?
I would suggest reach out to the mcebuddy forum, they’re pretty responsive.
Solved! Used oldmike's procedure from 2/15/2015 which relocates (I copied) files from bin folder to c:\\python27 folder. -list, and download/convert to MP4, both work fine. I did see that a 1 hour 35 minute movie took 23 minutes to download and convert.
@brian0I had similar results using hdmkv's procedure:[Feb 25 12:45:19 2015] [192.168.3.185] - Converting video to .mp4[Feb 25 12:45:19 2015] [192.168.3.185] - Creating mp4 fileTraceback (most recent call last):File "tablo2go.py", line 1051, infilename = get_video(ipaddr, show_id, tmsid, rDict(OPTIONS, ['ffmpeg.exe'], 'ffmpeg')[0], OPTIONS, FLAGS, show_proc)File "tablo2go.py", line 871, in get_videosubprocess.call(cmd)File "C:\\Python27\\lib\\subprocess.py", line 522, in callreturn Popen(*popenargs, **kwargs).wait()File "C:\\Python27\\lib\\subprocess.py", line 710, in __init__errread, errwrite)File "C:\\Python27\\lib\\subprocess.py", line 958, in _execute_childstartupinfo)WindowsError: [Error 2] The system cannot find the file specifiedHave you figured out how to correct so the script works?
My procedure was simply downloading the recorded stream as is (and not my procedure; just following script commands on page 1 of this thread); what you have above looks like it’s trying to convert?
- I did not need to install any additional software. I just simply downloaded the latest tablo2go file (from https://sites.google.com/a/moboard.com/tablo/) and moved the .py file to my media directory.
- Python is already installed by default in Mint - I had no need to install it.
- ffmpeg has been replaced by avconv starting in Ubuntu 14.04 / Mint 17, and uses the same syntax. Again, I did not need to install it (included in libav-tools package), but I did need to tell tablo2go to use this program instead of ffmpeg using the option you kindly provided.
- The auto detect IP address of my tablo didn't work for me, but I have mine assigned a static IP address, so I just use that and didn't investigate further.
cd ~/Media_Librarypython tablo2go-2.0.56.py -tablo:192.168.1.50 -ffmpeg:avconv -list
I’m trying to use TTG on a Mac. I’m calling TTG with:
./tablo2go-2.0.56.py -tablo:192.168.0.63 -ffmpeg:graham/Aplications/ffmpeg -db:./tablo2go.db -output:/Users/graham
Alleges well until (I think TTG calls ffmpeg, then I get this:
[Mar 8 15:01:45 2015] [192.168.0.63] - Creating mp4 file
File “./tablo2go-2.0.56.py”, line 1051, in
filename = get_video(ipaddr, show_id, tmsid, rDict(OPTIONS, [‘ffmpeg.exe’], ‘ffmpeg’)[0], OPTIONS, FLAGS, show_proc)
File “./tablo2go-2.0.56.py”, line 871, in get_video
File “/Library/Frameworks/Python.framework/Versions/2.7/lib/python2.7/subprocess.py”, line 522, in call
File “/Library/Frameworks/Python.framework/Versions/2.7/lib/python2.7/subprocess.py”, line 710, in init
errread, errwrite)
File “/Library/Frameworks/Python.framework/Versions/2.7/lib/python2.7/subprocess.py”, line 1335, in _execute_child
raise child_exception
OSError: [Errno 2] No such file or directory
@Graham Just guessing, but I wonder if ffmpeg on a Mac is just simply ffmpeg rather than ffmpeg.exe (like on WIndows). If so, you could try the same trick I used on Linux using the -ffmpeg: option. It is probably also case sensitive.
@chuckc I think that’s how I called it in the command line? I’m wondering if the .exe is hard coded somewhere…
@Graham ,
I got it from there, but via a different route I think!
@chuckc I think that's how I called it in the command line? I'm wondering if the .exe is hard coded somewhere......
No - The .exe is not hard coded if you use the “-ffmpeg:” option, but it is assumed without it.
My wife already has something like 50 episodes of the total 98 episodes over 4 seasons of one of her favorite western shows recorded.
@ShadowsPapa - Yes, this will work perfectly for what you want to do.
Wow, thanks. @jskenney it Can’t get any easier than that. I could create a VBscript to prompt me for a show title and make it as simple as using a shortcut, typing a show name, hit enter and letting it go to work.
I could have it wait until tablo2go was finished and then log the start and stop times, or pop-up a box when it was finished, or show any errors and so on anyway, something similar to that, that’s a rough guess until I look at details.
I’m old skool and work my tricks with VBS.
I found it a lot easier just to keep the ffmpeg in the same folder as python scripts - especially since it’s a stand-alone exe without any need for a specific home or folder structure. So - it’s in the “current directory”.
@ShadowsPapa - Sorry to get offside with a change of topic, but you mentioned saving shows to DVDs for long term preservation. I have a WARNING for you.
I understand the warning and can appreciate it, but yeah, I’d never count on a single copy of anything on a DVD as my only good copy. I’m super-paranoid so I’d always keep multiple copies, including originals on hard drive which I’d move to different drives as even hard drives can fail or fade.
I’ve had decent luck with DVDs so far. Maybe it is luck, dunno.
I’m not only paranoid, I’m a paranoid packrat. I have things from computers and years I can’t even remember. When I burn things to DVD, the source is always kept off on a drive that’s checked every so often for integrity. My goal is to get them off the Tablo drive, get them to a medium that’s easy for my wife to use (pop a disk into the player and enjoy) while having a archive of the originals off elsewhere.
For me DVDs are a disposable “convenience” medium for her. I would not delete originals as I have that SATA dock and use older drives to archive things I really want to keep safe.
My main goal is to get the shows off Tablo as it would otherwise eventually fill. (dang, then I’d have to make some choices!)
This burning to DVD is more for keeping the Tablo “on-line storage” clear and make it convenient for my wife. she likes to SEE a physical thing, a DISK she can hold and put into a player.
DVDs would be off-line storage,
and another drive would be near-line storage - available but not IN Tablo.
By the way, anyone interested in original install disks for Windows 3.0 from Northgate computer systems? I found my originals and some backup copies the other day.
