@pngwolfman, make sure you are downloading python 2.7 and not version 3.
Ideally a correct installation of Python 2.7 should have no problem finding standard modules like urllib2.
Something does appear to be wrong with your python install (that’s my best guess).
@dean5417
Make sure you have Rename and Sort by video information checked and Enable custom file renaming. Here is what I have for custom renaming
%ShowName%\Season %season%##\%ShowName% - S%season%##E%episode%## - %episodename%
Thanks. I have those checked and something similar for the custom renaming. Update: got it working now with .Mp4 and mp4tag false which fixed the season/episode # issue. To fix the issue where it wouldnt recognize the file as a movie, I split movies apart from TV into different directories pre-Mcebuddy then have separate monitors looking at each.
Excellent! My goal is just a bit different though; to be able to copy from the tablo specific and new tv shows and store them for much longer term on my plex server, which has an absurd about of storage space. This way the plex server itself has the shows integrated so I can watch two year old episodes of shows like Big Bang Theory (I just finished the last season during the most recent rainy day.)
I’m with you 100% on this. I want to save TV series to watch later. My collection currently spans over 3 3TB WD drives. This is something Tablo can’t do. I have a Plex server whic works great with my LG smart TV.
Thanks to all, I hope to work through the step by step today. You may not consider it as patching up a Tablo miss, but I just want to get all shows off so that I can swap to a 2TB drive and stop manually deleting news shows, etc, every third day, because there is no way to limit the number of recordings or easily delete many at once.
Followed the step by step, works fine, but the last step returned “No videos have been queued.” So no MP4 file returned. It found my tablo, 39 video’s metadata, just did not return the video itself. I am under Windows7-64.
Well this is odd: I made a VBScript to get file name and then launch the command line, but it was messed up and did not pass in the file name. But the program ran! It returned one of the files on Tablo, but it is a .TS file, not MP4. I’m pretty ignorant re: video file formats, etc. Is there another step or converter I need?
BTW: my first issue ( No videos have been queued ) seems to be because the file name is case sensitive. Now all I gotta do is figure out the TS vs MP4 thing.
Even more odd: I was premature to say it ran when using the correct case for file name. Got error messages; however it did in fact produce the TS file. Found a free converter, converting to MKV now. I only have 22 to do, then I’ll drop in the 2TB drive and format it.
@oldmike ,
Many thanks kenny. I have no movies, so this should work just great. Let you know!
Got
Ah; the steps did not include to put the executables of ffmpeg into the top of the python27 directory. I copied all of the binaries into it, and now it seems to be running fine.
First one is out, an MP4 of 650MB. VLC says it will play it, but it does not and it shows the file to be zero minutes long.
The MP4 will not play through Plex.
OK, now even more odd. In the CMD window the updates say “Deleting .ts file”, but what I have on the output is all .ts files. So I renamed on to .MP4 and it plays! So I think there is a bug in the script, and the file I could not play was actually a .TS file marked as MP4. When placed into the Plex files with the proper name and folder name (Plex is very fussy about that) they play fine. My guess would be that the script does delete the TS file, but then does not rename the converted file to MP4, leaving it as .TS. But a simple edit of the file type yields a fine MP4 file.
So, now I’m really confused and embarassed. I relaunched the script, and was watching files download, then disappear. But looked at the CMD dialog, and saw that they were being moved to a .TV folder, and sure enough there are the shows, in folders and with names and episode numbers that Plex will like. No idea about the .TS files that were actually .MP4 files I saw before, but right now it is just perfect, and I thank all concerned. Now I’ll try to stop taking up anyone’s time. Thanks again.
Boy, was that slick. Thanks to all involved. Now I can swap in a 2TB drive.
Played my first Plex file from Tablo. The last three minutes was cut off, so didn’t get to finish. I’ll try another tomorrow to see if it is systematic.
