What will happen to the recording when the Tablo loses signal from the antenna due to a storm or other such factor and then receives the signal back a few seconds later?
I don’t think the Tablo has a resume/retry ability if the signal is lost at this point. Similar if it happens when you’re watching, the feed either stops or just displays the white progress bar and freezes until you cancel and re-select the channel. Since it’s acting like not just a tuner, but a tuner and converter, maybe only one of the two is the issue? Maybe it’s a bug?
@guck11 This really depends on the severity of the inclement weather conditions and how they affect the packet loss rate. This case isn’t black and white, it’s really relative to the corruption rate. It some instances the recording will fail altogether due to (weather) corruption, in others you may simply have some patchy-ness here and there.
@TabloSupport and @Itldevl thanks for the response.
I will add my vote for continuing recording if the power or signal loss happens. Notifications would be good for this too
@guck11 @Jestep Thanks for the feedback - I’ll speak to the team and pass this along to the engineers.
In my case it dropped the recording. That’s when I was using a crappy indoor antenna and Chromecast. Nightmare scenario.
